2 members (Hotrod Lincoln, KCMongo), 59 guests, and 1 robot.
Topics128,050
Posts1,055,639
#1085780 02/15/2015 7:36 PM
So when it comes to door hinge bolts what kind of washers do you use, split ring or star type? Also will it matter if you use a bolt where the head is just a tad thicker than the original?
Joe
jremig #1085797 02/15/2015 8:49 PM
This site covers trucks from the '20s to the '70s. You need to be more specific.
jremig #1085833 02/15/2015 11:45 PM
AD hinges take split washers on the door, and stars on the pillar. I don't know how much clearance room there is on the pillar bolts. They made them thin for a reason.
Carl
jremig #1085909 02/16/2015 4:29 AM
External star washer
You can use a thicker head bolt
...pic...
...pic...
...pic...
jremig #1086360 02/18/2015 2:21 AM
I wonder why GM went with the skinny-headed bolts. They are a pain to take off when they are a little rusty, and are easily goobered up since they have less metal for the socket to grab.
Carl
