| | | Forums66 Topics128,097 Posts1,056,494 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | I've been reading here about adding power steering to my original steering box. So then can I modify my original steering wheel to a smaller diameter? safely? Like cut the spokes, and attach a newer wheel rim?
I don't need tilt column, or column auto shift, so I was thinking the original column would be fine.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a smaller diameter wheel works fine with power steering, but I wouldn't want to trust/use a home modified wheel, many more modern wheels will fit the original splines
Bill | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | There are smaller (15") reproduction steering wheels made for many of our trucks, do a web search for your year truck and see what you find. Mike B  | | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | | | | | | Joined: Apr 2005 Posts: 2,099 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,099 | Any GM wheel through the 70's will fit the shaft. Possibly later ones will fit as well. I used a 3 spoke wheel from a Fiero. It has a similar look to the stock wheel but considerably smaller. Fred
