5 members (5 Window 9434, Jon G, John Dlugos, jmoore, moparguy), 96 guests, and 4 robots.
Topics128,120
Posts1,056,325
Members48,439
I've been reading here about adding power steering to my original steering box. So then can I modify my original steering wheel to a smaller diameter? safely? Like cut the spokes, and attach a newer wheel rim?
I don't need tilt column, or column auto shift, so I was thinking the original column would be fine.
a smaller diameter wheel works fine with power steering, but I wouldn't want to trust/use a home modified wheel, many more modern wheels will fit the original splines
There are smaller (15") reproduction steering wheels made for many of our trucks, do a web search for your year truck and see what you find.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
ok, thanks
Any GM wheel through the 70's will fit the shaft. Possibly later ones will fit as well. I used a 3 spoke wheel from a Fiero. It has a similar look to the stock wheel but considerably smaller.
Fred
