| | | Forums66 Topics128,081 Posts1,056,069 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 160 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 160 | I am trying to update the rear brakes on my torque tube axle from the '50 hucks to the '51-'53 bendix. I found a '53 complete axle for sale - can I just swap the backing plates, etc between the two? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | No, you will need to change the whole axle housing.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2013 Posts: 160 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 160 | Thanks. Can you specify the differences? For example the "innards", torque tube,etc?, or is it just where the plates mount to the housing? My plan would be to use the best parts from both as much as possible, without mix-matching the gear sets. Also thinking about the 3:55 swap. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The problem is the offset in the backing plates. Even if you remove the backing plates the mounting flange welded to the housing is in a different position.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2013 Posts: 160 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 160 | Thanks again. I see the problem. This forum is a money saver! Bookmarked your blog too, lots of good stuff there. | | |
