2 members (Thomaslb, Eddie54), 166 guests, and 0 robots.
Topics128,080
Posts1,056,060
Members48,433
I am trying to update the rear brakes on my torque tube axle from the '50 hucks to the '51-'53 bendix. I found a '53 complete axle for sale - can I just swap the backing plates, etc between the two?
NHluvstruck...
1951 3100 5-window,.sold, regretted
https://stonefacegarage.wixsite.com/mysite
51 Chevy Restoration Page
No, you will need to change the whole axle housing.
My Blog
Thanks. Can you specify the differences? For example the "innards", torque tube,etc?, or is it just where the plates mount to the housing? My plan would be to use the best parts from both as much as possible, without mix-matching the gear sets. Also thinking about the 3:55 swap.
NHluvstruck...
The problem is the offset in the backing plates. Even if you remove the backing plates the mounting flange welded to the housing is in a different position.
My Blog
Thanks again. I see the problem.
This forum is a money saver!
Bookmarked your blog too, lots of good stuff there.
NHluvstruck...
