1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | My radiator has been declared DOA by my trusted radiator guy. I am inclined to go with an aluiminium replacement.
Any thoughts or recommendations?
Mike
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I went with US radiator, with a polished top, it was expensive, but it will last till I die. The only real advantage to aluminum is they are cheaper. The brass looks better, and cools better. The aluminum can withstand higher pressure, but in these vehicles that isn't an issue, the aluminum is also lighter, but here again, it isn't going to affect handling or fuel economy. | | | | | Joined: Feb 2000 Posts: 5,194 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,194 | I found my aluminum one cools very good and holds more coolant, I guess the tubes are bigger then the rebuilt one I was using. Due to the engine and truck combination I am using, I have to custom fit the radiator, so being a almost direct fit didn't bother me.
Joe | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Your radiator guy can't build you one?
Bill Burmeister | | | | | Joined: Mar 2014 Posts: 161 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 161 | The radiator that came with my 51 3100/235 was severely rotted.The radiator shop put a new core in it. Perfect.Unless youre gonna run a hi pro motor you should do fine doing the same.---Jack | | |
