5 members (Charles in CA, klhansen, FishinToms53, Hanks custodian, 5 Window 9434), 53 guests, and 0 robots.
Topics128,049
Posts1,055,634
#108541 04/15/2003 10:41 PM
Has anyone out there had rust along the edges of stake pockets? I am in the midst of restoration and need to know if anyone has had success NOT removing the stake pockets but sanding off the rust and applying rust converter, then priming and painting. I am relatively new at this and want to know how much I can trust the rust converter to really work. Please let me know if you have had experience with this. Thanks, Scruff.
#108542 04/16/2003 6:04 PM
I've had lousy results with the rust converters. The encapsulating paints seem to do much better. Por-15, Zerorust or Hammerite. With them you remove as much rust as possible, clean and paint, and they seal out the moisture.
Fred
52 3600
69 C-10
#108543 04/22/2003 2:34 AM
Thanks Fred, I appeciate the advice. Zero-Rust sounds like a pretty good way to go. That's probably what I'll go with.
#108544 04/26/2003 5:40 AM
Anonymous
Unregistered
Anonymous
Unregistered
Hooligan, if your stake pockets are rusted through you may want to try locating some rust free Arizona ones [ avaliable in the Swapmeet section ].
