| | | Forums66 Topics128,043 Posts1,055,611 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 10 Member | | Member Joined: Feb 2003 Posts: 10 | Has anyone out there had rust along the edges of stake pockets? I am in the midst of restoration and need to know if anyone has had success NOT removing the stake pockets but sanding off the rust and applying rust converter, then priming and painting. I am relatively new at this and want to know how much I can trust the rust converter to really work. Please let me know if you have had experience with this. Thanks, Scruff. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I've had lousy results with the rust converters. The encapsulating paints seem to do much better. Por-15, Zerorust or Hammerite. With them you remove as much rust as possible, clean and paint, and they seal out the moisture.
Fred 52 3600 69 C-10
| | | | | Joined: Feb 2003 Posts: 10 Member | | Member Joined: Feb 2003 Posts: 10 | Thanks Fred, I appeciate the advice. Zero-Rust sounds like a pretty good way to go. That's probably what I'll go with. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Hooligan, if your stake pockets are rusted through you may want to try locating some rust free Arizona ones [ avaliable in the Swapmeet section ]. | | |
