5 members (tclederman, FAST55, Joe H, lumbersawyer, 1 invisible), 69 guests, and 2 robots.
Topics128,023
Posts1,055,367
Members48,420
#1085341 02/13/2015 5:28 AM
My radiator has been declared DOA by my trusted radiator guy. I am inclined to go with an aluiminium replacement.
Any thoughts or recommendations?
Mike
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
MikeE #1085362 02/13/2015 1:05 PM
I went with US radiator, with a polished top, it was expensive, but it will last till I die. The only real advantage to aluminum is they are cheaper. The brass looks better, and cools better. The aluminum can withstand higher pressure, but in these vehicles that isn't an issue, the aluminum is also lighter, but here again, it isn't going to affect handling or fuel economy.
MikeE #1085385 02/13/2015 4:11 PM
J Online: Content
I found my aluminum one cools very good and holds more coolant, I guess the tubes are bigger then the rebuilt one I was using. Due to the engine and truck combination I am using, I have to custom fit the radiator, so being a almost direct fit didn't bother me.
Joe
MikeE #1085452 02/13/2015 10:16 PM
Your radiator guy can't build you one?
Bill Burmeister
MikeE #1085487 02/14/2015 3:30 AM
The radiator that came with my 51 3100/235 was severely rotted.The radiator shop put a new core in it. Perfect.Unless youre gonna run a hi pro motor you should do fine doing the same.---Jack
