3 members (2-Ton, kbenz, MNSmith),
161
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Hello all- I ran out of daylight trying to get the wiper motor assembly out of my truck (55.2 Chevy 235 w/original vac wipers). I removed the three clutch head screws that were mounting the wiper motor under the dash, but that is as far as I got. So for tomorrow, does the wiper motor & arm assembly come out (uninstall) as one component; or, do the actuator arms separate from the wiper motor? All I felt that felt removable was a return spring & I don't want to break anything. I need to remove the motor to get the metal behind it clean & here's the pictures of it. . Thanks Brad Wrench Fetcher, PhD | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Brad see the spring with eyelet on each end where the two arms hook to the wiper motor. Pull on the eyelet to stretch the spring a little bit so you can pull it off the end of the stud. That's what holds the wiper linkage to the motor. Then slide the eyelet off the other side to remove the other linkage arm. After you get the first eyelet off, you'll see how simple a retainer setup it is.
Brian
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Thanks Brian- I'll give it a try again. That thing must need a shot of blaster or other break free lube...
So, the motor will come out by detaching at that point, but do the linkage arms remain attached at the inside of the cowl? (The wipers pivot point? )
Brad
Wrench Fetcher, PhD | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | The linkage arms with the wiper pivot point are fastened to the inside and outside of the cowl. Just study how they are fastened on, it's all pretty basic stuff, and you shouldn't have any problem doing it.
Brian
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Alrighty- it'll be a piece of cake & I'm sure being able to see in the daylight will help. It's remarkable how much space the wiper assembly used to take up under the dash to allow for arm movement. Neat stuff. Thanks Brad Wrench Fetcher, PhD | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Here's a picture of the retainer spring. See how the hole gets bigger so when you push the eyelet forward it will release itself off of the wiper motor stud. Don't worry about breaking the spring (you probably won't) but if you do, you can get a new spring retainer for cheap from a parts vender. http://www.americanclassic.com/images/WW107.JPGBrian
