2 members (R&S 51 GMC, Tiny),
152
Mod | | | Forums66 Topics128,125 Posts1,056,338 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 | I have a '46 2 ton that arrived just before winter that doesn't run. I wasn't able to get much of anything done on it because it got cold quick. However, the engine in it is a replacement with no id tag. It just a a GM 48 on the side. I have a '42 that came with a 216 identical to the one in the 2 Ton. A replacement with GM 48 stamped on the side. That was it. My question is, is it possible that the 2 ton also runs on a 216? Did 1 1/2 and 2 tons have 216's in them? Is there any way, other than physically measuring to see if this is a 235 or a 216?
1942 BK 1/2 Ton Pickup 1954 3800 1 Ton Pickup
| | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | While 2-tons left the factory with 235's under the hoods, a 216 will fit right in there. I fact, I'm running one in mine right now. When I can afford to get the 235 rebuilt, it will go back in but the 216 does the trick for now. | | | | | Joined: Dec 2010 Posts: 97 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 97 | This doesn't answer your question but the Canadian army ran 216s in trucks up to 3 ton 4x4 throughout WW2 so the 216 certainly could have been used in trucks as heavy as your 2 ton. For the 3 ton 6x6 they went with the 270.
| | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | I think it is common for the big trucks to be seen with 216s. While originally they may have had the low-pressure 235s - I'm not certain whether they were standard or just an option, but Tim is probably right - the biggest weakness of the Chevy six was the thin casting, which led to the blocks cracking in the water jacket. My fire truck had this happen, and the department repowered it with a 216, because . . . well, 216s are a dime a dozen! They could get one at the local salvage yard, and it only lacked like 7 horsepower compared to the 235 (I know, I know . . .it's the torque that matters! Still . . . ).
Anyway, there's no doubt that for the big trucks, the 216 is underpowered. However, the original 235 was ALSO underpowered, and it was the biggest engine they had. There's a reason they come with that stump-puller 1st gear! That being said, I run my truck occasionally with it's full complement of equipment and 500 gallons of water. It's slow, but it goes! Without the water, I find it satisfactory, and usually enjoyable. Someday, I'll find the low-pressure 235 to rebuild and put in. Someday . . .
-Michael | | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 | Thanks for the input. Like I said both engines don't have a serial number. Funny thing, thanks to this post I found that the engine that I thought was a 216 that came from my '42 1/2 ton was actually a 235. Interesting.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Some field rebuilds have no SN's on the block. A 261 will fit in there, be careful to identify correctly, look almost like 235.
