5 members (Otto Skorzeny, Wickedbass, Hanks custodian, 32Fordpuchoptop, Gdads51), 67 guests, and 2 robots.
Topics128,094
Posts1,056,048
Members48,433
#10850 05/27/2005 8:56 PM
I came across a 4 speed trans with a granny gear out of a 72 truck for $100, the trans has four bolts to meet up with the bellhousing. I have a 235 in my 53 truck with a SM420 4 speed on the floor (no cyncros SP). I am in the process of changing the rear end and loosing the closed driveline. I know I will have to have a drive shaft made or find one the right length. Other than that, it appears this should just bolt up and I should be in good shape. Is this true? Clutch problems/issues, or anything else that I need to know about the swap.
Lastly, if I decide to go to a V8 in the future(keep that quiet), will it work well with the V8.
Any information or imput would be great.
If you didn’t skin a knuckle while you were working on your truck, you weren’t working hard enough!
53 5window 1/2 ton
54 3window 1/2 ton
#10851 05/27/2005 10:17 PM
Riding in the Passing Lane
Check the diameter of the front bearing coller & make shure it is the same where it fits in the bell housing. There are some variations there. Some have the E-brake on the back of the trans. If that fits it should work. The v-8 also will work using a matching bell housing. This is a tough trans. It should make a worthwhile swap.They are difficult to o-haul though but some repairs can be made without a complete teardown.
1972 Chevy c10 Cheyenne Super
#10852 05/27/2005 10:21 PM
Wrenchbender Ret.
Thanks for the info. I will measure the bell housing opening when I pull the old trans.
How hard is it to find another bell housing that matches, or can the existing bell be opened more if need be?
Dan
53 5window 1/2 ton
54 3window 1/2 ton
#10853 05/27/2005 10:47 PM
That tranny is likely to be a CH-465 just for the record. They were used all the way up through the 60 series.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
X
X Offline
Dan, are you saying that the SM420 that is in your truck now isn't synchronised? If it's a '53 tranny, it should be sycnchro (except 1st gear).
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
Thanks guys,
As usual, you all provide and great information and insight. I sent you some email questions directly.
Xram53, I haven't had the truck running but, I believe the drivetrain is the original since it is the sealed driveline. I also haven't had a chance to clean all the crud off of the trans to get the numbers for positive identificaiton. I hope to get to that in the next week or so.
I will let you know what I come up with.
Thanks again to everyone.
53 5window 1/2 ton
54 3window 1/2 ton
If your tranny has reverse to the left and down, it is the SM420. I actually prefer this to the later SM465, reverse to the right and down. The 420 has the advantage of being a faster shifting box, but both are durable boxes. For some general info go to http://www.novak-adapt.com/knowledge/knowledge_gateway.htm
The bell housing will need machined to work, but it's minor. You could use a bell from a 68-72, but the starter and cluth mounts are different.
Fred
52 3600
69 C-10
