3 members (J Lucas, Wally / Montana, Wickedbass), 109 guests, and 0 robots.
Topics128,075
Posts1,055,916
Members48,429
#108488 03/27/2005 1:25 AM
Gonna start painting the 2 tone portions of my project. Omni Brand. I thought I would paint the first color(black), let it dry at least as long as the tech sheet says, tape it off and then go with the next color(burgundy).
My questions: Am using the low tack blue masking tape, just a generic brand.Is this OK or do I need something special.
After I paint the second color and I pull the tape there will be a line. Is the normal proceedure to clear over this and make it disapear that way? Most of this line will be in a seam but not all of it.
thanks
Jim
#108489 03/27/2005 4:03 AM
I've had trouble with the blue stuff not being sticky enough. I like the $$ 3M green stuff. If you're using a base/clear you shouldn't have too bad of a break line because you don't need as much color as you would with enamel or urethane. The clear does most of the work. Are you striping between the two colors or are you leaving the break line exposed?
Keith
If it were easy they'd have grade schoolers doing it!
#108490 03/27/2005 6:37 AM
I believe the blue tape is household stuff. Keith is correct get the 3M good stuff.
You may want to get some "fine line" tape. It comes in different dimensions, 1/16, 1/8, 2/4...
You can find it at your local Paint store.
This will give you a very nice line. Masking tape has a rough edge.
Lay this tape out and then apply the 3M stuff with paper on top of that.
Good Luck!
Regards, Kevin
1940 1/2-ton (Uncle Willie\'s truck)
Thanks for the help so far fellow Bolters!
#108491 03/27/2005 10:36 AM
The blue stuff has a crepe to it which lets paint bleed under it and I find it useless for nice edges even in the house. You want automotive masking tape, the fine line or the green stuff. You might want to visit your auto paint store.
Paint & Body Shop moderator
#108492 03/27/2005 7:21 PM
I
I Offline
That blue stuff has given me problems in the house too.
I have heard of covering the line with clear. I have also heard of using an extremely fine sandpaper for evening out the line. Sanding to me though sounds dangerous (but I have no experience here).
Check out the Autobodystore.com forums.
I have never done any work like this but it seems the problem you describe is the same one you would encounter doing stripes or flames. there are several discussions on this at the Autobodystore.
Don't you know who I think I am?
I've been thinkin' about freaking out. If I could just find the time.
http://community.webshots.com/user/ifrizlfri
#108493 03/27/2005 10:20 PM
thanks guys. as my wife says, i'd better ger my arse out of bed early and get to napa for some green tape. can always count on this forum for good advice. hope someday i can be the guy with all the answers grin so I can be of some help.
thanks again
jim
#108494 04/01/2005 2:42 AM
well I painted last weekend and had really good results. Did buy the edging tape but I think the clear would cover about anything. The tape did make a nice clean edge though. Will post picts when their buffed.
Jim
#108495 04/01/2005 7:56 AM
46 Burb, glad that it worked out. I was hoping to get my first color on my cab this weekend but I havn't got the paint yet. Maybe today. It's coming in the mail.
I'm actually painting single stage on the interior then taping that off to paint the rest with the two stage exterior color. I will be using the fine line tape myself.
Show some pics when you can!
Regards, Kevin
#108496 04/05/2005 7:49 PM
Junior Member
Junior Member
The blue tape is made for long term placement.
Don
Don Meyer-PhD,mech engr
#108497 04/11/2005 1:48 AM
how's this? cant wait to color sand and start some assembly
jim
[img]http://truck.jandcawards.com/img74.jpg[/img]
#108498 04/11/2005 4:16 AM
I like the color combination. Seeing you guys getting color on makes me envious.
Ralph Davis
1970 Chevy C10 Webshots
My Stovebolt Gallery page
Old trucks never die, they just find a new home.
#108499 04/11/2005 7:40 PM
I'm really envious!! I've been working on getting the painting done for two long years. Yours looks really great!!!!!! Redcoat
#108500 04/13/2005 1:28 AM
thanks,
color sanding now. been 2 evenings now and have the first sanding with 1000 done on the side you see there. will be doing 1500 then. More picts to come. maybe when the rear fenders are on.
thanks
jim
#108501 04/14/2005 7:43 AM
46, that is going to be a fine ride!
Looks great so far. Good luck with the sanding.
I'm just about to start color sand my cab. before monting it on the frame.
If you haven't seen a pic yet I posted it on General talk under the 39 to 40 differences topic.
Check it out.
Its great to finally see some color.
Keep up the good work!
Regards, Kevin
