1 members (delky),
65
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 34 | I have just installed a new 7 wire turn signal switch from American Classic. I ran new wires for tail lights and turn signals. Also installed new 2 bulb tail lights and new grounds. Everything works except the brake lights. When I pull out the brake light switch on the flasher the rear flashers flash. With the switch off the brake lights don't work when you depress the brake petal. I also rewired the brake switch. Does anyone have an idea what I should try next? David
1952 Chevy 3100
| | | | | Joined: Mar 2014 Posts: 195 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 195 | How sure are you about the wiring? Do the flashers work without braking?
I had some issues too when I rewired all the cables to the lights. They were caused by a bad ground on the steering column. So check all the grounds!
Edit: Or maybe just a bad brake switch. you could test it by taking it out, and connect it directly to a bulb from the battery. and also connect the -side.
Chevrolet 3100 Year: 1951 engine: inline 6 217CI Transmission: Manual 3-Speed. 12Volt. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Make sure the wire feeding your brake light switch is connected to a hot-all-the-time terminal. I believe the '52 is connected the same as my '38 in that the terminal is on the light switch.
| | | | | Joined: Jan 2015 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 34 | The flashers, head lights and tail lights all work properly. The instructions stated that when the rear knob is pulled out the brake lights stay on. When I pull it out the lights flash like emergency flashers. Does anyone know the true function of this knob? David
1952 Chevy 3100
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The quote from the instructions doesn't make a lot of sense. I don't know of a circumstance where one would want to turn the brake lights on. Usually there is a pull switch to activate the four way flashers. | | | | | Joined: Jan 2015 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 34 | I'm going to call American Classic tomorrow to clarify.
1952 Chevy 3100
| | | | | Joined: Mar 2014 Posts: 195 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 195 | it looks like that knob is for hazard lights as truckernix said. Never seen or been in a car wich had a "turn-on-brak-lights-function" Chevrolet 3100 Year: 1951 engine: inline 6 217CI Transmission: Manual 3-Speed. 12Volt. | | |
