4 members (klhansen, baldeagle, Southerntruck, Lightholder's Dad), 96 guests, and 2 robots.
Topics128,035
Posts1,055,552
Members48,425
#1084531 02/09/2015 2:50 AM
I have just installed a new 7 wire turn signal switch from American Classic. I ran new wires for tail lights and turn signals. Also installed new 2 bulb tail lights and new grounds. Everything works except the brake lights. When I pull out the brake light switch on the flasher the rear flashers flash. With the switch off the brake lights don't work when you depress the brake petal. I also rewired the brake switch.
Does anyone have an idea what I should try next?
David
1952 Chevy 3100
dg1952 #1084596 02/09/2015 1:18 PM
How sure are you about the wiring? Do the flashers work without braking?
I had some issues too when I rewired all the cables to the lights. They were caused by a bad ground on the steering column. So check all the grounds!
Edit: Or maybe just a bad brake switch. you could test it by taking it out, and connect it directly to a bulb from the battery. and also connect the -side.
Chevrolet 3100
Year: 1951
engine: inline 6 217CI
Transmission: Manual 3-Speed.
12Volt.
dg1952 #1084605 02/09/2015 2:28 PM
Ex Hall Monitor
Ex Hall Monitor
Make sure the wire feeding your brake light switch is connected to a hot-all-the-time terminal. I believe the '52 is connected the same as my '38 in that the terminal is on the light switch.
dg1952 #1084687 02/09/2015 9:21 PM
The flashers, head lights and tail lights all work properly. The instructions stated that when the rear knob is pulled out the brake lights stay on. When I pull it out the lights flash like emergency flashers. Does anyone know the true function of this knob?
David
1952 Chevy 3100
dg1952 #1084754 02/10/2015 2:49 AM
The quote from the instructions doesn't make a lot of sense. I don't know of a circumstance where one would want to turn the brake lights on. Usually there is a pull switch to activate the four way flashers.
1951 1 Ton Completed
dg1952 #1084756 02/10/2015 2:55 AM
I'm going to call American Classic tomorrow to clarify.
1952 Chevy 3100
dg1952 #1084810 02/10/2015 8:06 AM
it looks like that knob is for hazard lights as truckernix said. Never seen or been in a car wich had a "turn-on-brak-lights-function"
Chevrolet 3100
Year: 1951
12Volt.
