0 members (),
133
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 17 New Guy | | New Guy Joined: Feb 2014 Posts: 17 | I just updated my truck to a 2 speed electric wiper from the vacuum wiper. I need to find out how the vacuum lines need to run with this new setup. Can anyone help me? Bob | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Callmebob, actually the vacuum wiper lines can be removed entirely and their source of vacuum at the intake manifold can be capped or plugged, hope that helps. | | | | | Joined: Feb 2014 Posts: 17 New Guy | | New Guy Joined: Feb 2014 Posts: 17 | My truck will not idle if I plug the manifold port. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | well you have a problem, because that is how it is done. Did you have a vacuum leak somewhere and have the carb adjusted to compensate? | | | | | Joined: Feb 2014 Posts: 17 New Guy | | New Guy Joined: Feb 2014 Posts: 17 | That could be possible because the vac wipers didn't work. Thanks I'll check it out today. | | |
