7 members (crenwelge, DadsFirstPickup, Hotrod Lincoln, Peggy M, Otto Skorzeny, 2 invisible), 99 guests, and 3 robots.
Topics128,127
Posts1,056,675
Members48,450
#1084537 02/09/2015 3:00 AM
I just updated my truck to a 2 speed electric wiper from the vacuum wiper. I need to find out how the vacuum lines need to run with this new setup. Can anyone help me? Bob
3B Offline
Hy Callmebob, actually the vacuum wiper lines can be removed entirely and their source of vacuum at the intake manifold can be capped or plugged, hope that helps.
My truck will not idle if I plug the manifold port.
well you have a problem, because that is how it is done. Did you have a vacuum leak somewhere and have the carb adjusted to compensate?
That could be possible because the vac wipers didn't work. Thanks I'll check it out today.
