2 members (ShopRag, LAROKE),
44
Mod | | | Forums66 Topics128,090 Posts1,056,347 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | Prior to restoration, the nose piece on my hood (and the grill too) was slightly "leaning" to the driver's side. Now that the grill is restored and a new (off junker) "nose" piece on truck, when looking at the truck there is a gap between the "wing" off the hood and the nose. Any thoughts? New hood hinge? Brace up hood hinge? | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Didn't happen on mine but think there is only a few adjustments. I would check the shims under the radiator mount. You may gain some movement/adjustment there. Also on the V piece connected to radiator and firewall you may have some adjustment in and out. Hope this helps. Have fun and good luck Dan | | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | Thanks. Nose piece now looks straight. Left hood side tucks against it nicely. Right side has 1/4 inch gap. I'll try adjusting back near firewall.
