| | | Forums66 Topics128,052 Posts1,055,773 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | looks to me like the old bearing is still in place, otherwise there'd be a gap between the column and mast jacket .... compare to the new bearing and you should be able to see where to pry to get the old one up .... when you remove it the wire will pull up and out, attach a string to it so you have a way to 'fish' the new wire in
Bill | | | | | Joined: Jan 2015 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 34 | Does the upper bearing encase a ball bearing? In the photo you are seeing the top of a ball bearing.
David
1952 Chevy 3100
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I thought you said you just recieved your bearing from American Classic parts??? The bearing and horn contact is one assembly potted in rubber: mast jacket bearing Pop the old one out and press the new one in, thread the wire back down thru the hole half way down and that's it, no more complicated than that. DG
Denny G Sandwich, IL
| | | | | Joined: Jan 2015 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 34 | Dennny, here's some pictures that might show a little better. The flat area inside the column is the top of the ball bearing. Is there something else that needs to be removed? When I got the truck this is the way it came. It had a small steering wheel on it. David's Photo Bucket
1952 Chevy 3100
| | | | | Joined: Jan 2015 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 34 | I did just get the mast bearing in the picture that you posted. David
1952 Chevy 3100
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | David, the flat area ["ball bearing"] you point out is the old part that your new part will replace, they're identical, need to remove it as shown in DG's pic, although you don't need to fabricate a special puller like he did, just get under the flange edge that sits atop the mast jacket with a stiff putty knife and work around gently tapping it up until you can get hold of it, pulls right out with the horn wire attached to the back of it
Bill | | |
