Brrrr
place holder
2 members (Peggy M, MTD91), 141 guests, and 0 robots.
Topics128,274
Posts1,058,432
Members48,489
#1082820 01/31/2015 10:05 PM
What front end bolt in kits are available for my 58 GMC truck. Stock right now
Thanx
Danny
1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
dtwbcs #1082827 01/31/2015 10:43 PM
"converting" what? "front end" covers a lot of territory .... sounds like you may need to search the HiPo forum
dtwbcs #1082847 01/31/2015 11:47 PM
Sir Searchalot
Sir Searchalot
There are kits for tapered roller bearings, brakes and steering. If you want to switch from leaf to coil/bags. I'm out.
dtwbcs #1082881 02/01/2015 2:23 AM
Sorry 4 being vague.
What conversion kits are out there to replace the whole front end between the wheels<---for suspension brakes and all; like the mustang2 kit. Wanting the good, the bad, the ugly on kits smile
Danny
dtwbcs #1082885 02/01/2015 2:37 AM
I don't think there's any "bolt in" kits for that, they all pretty much are either going to need welded in, or require some sort of frame modifications to work. I will tell you, just from my experiences with them, stay away from anything Mustang 2 based. The Mustang 2 frontend is way too light to even be considered for any full size truck, like sending a boy to do a mans job, as Jerry would put it. If you do use a kit, find one that uses either GM Metric chassis (A and G body '78-'87, F body '78-'81) or C4 Corvette ('84-'96) parts. Or even better, if you don't mind a little fabrication, the entire C4 Corvette suspension crossmember can be had for less that what any of the conversion kits cost, and it's better parts. A crossmember from the '98-'12 Crown Victoria would also be a viable option. A '73-'87 C10 crossmember could also be used if you want to keep truck rated parts, but it will be a little wide.
Bill Burmeister
dtwbcs #1082939 02/01/2015 7:04 AM
interesting....
Danny
dtwbcs #1082959 02/01/2015 1:47 PM
ODSS Lawman
ODSS Lawman
What would you like this kit to accomplish? In other words, what do you see yourself using your truck for?
Many folks get a truck, take it apart without a plan
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
dtwbcs #1083092 02/01/2015 11:51 PM
everyday driving.I hasn't been on the road in 2yrs.I am either gonna start enjoying it or I am gonna get rid of it.So I bought a 3spd manual trans wOD.The truck is totally stock.so you know it looks/is high in front.
Jut seeing what I can do for smooth ride without breaking the bank
Danny
dtwbcs #1083111 02/02/2015 1:02 AM
Rebuild the stock springs and add the polyvinyl leaf liners and good set of gas shocks. You would be surprised at how well they really do ride and handle.
Bill Burmeister
dtwbcs #1083118 02/02/2015 1:15 AM
I think a nice rebuild with modern components is the way to go. My 65 c10 rides better than my 04 dodge
dtwbcs #1083137 02/02/2015 2:34 AM
Been focused too much on the car that I forgot about my Other "6" cool
Danny
dtwbcs #1083677 02/05/2015 1:33 AM
what about a dropped axle set up from droppedaxles.com ?
Danny
dtwbcs #1084221 02/07/2015 8:20 PM
Nobodys used this guy cool
Danny
dtwbcs #1084243 02/07/2015 9:34 PM
You mean Sid's ? I've never used them personally, but have never heard a bad thing about them either. If I were to lower my truck, that's the way I would go.
Bill Burmeister
dtwbcs #1084303 02/08/2015 2:46 AM
Yes referring to droppedaxles.com
Thinking this is the way to go with my truck but am looking for feedback ohwell
Danny
dtwbcs #1099823 04/28/2015 2:05 AM
Longbox55 I have a 55 3100 short bed. Is the Mustang 2 too light for it?
dtwbcs #1099850 04/28/2015 3:25 AM
Hi,
I rebuilt the stock front suspension, brakes, added a front sway bar, pulled one leaf out of the front and installed new 3 inch lowering springs on the rear of my '56 short box. Also added radial tires and tapered roller bearings. It rides and steers better than new.
