0 members (), 146 guests, and 5 robots.
Topics128,266
Posts1,058,385
Members48,485
#108416 04/03/2004 5:59 AM
I am looking for advice. What I am trying to figure out is how to fasten stainless steel together. 24 guage lap joints is what I need to do. The lap joint will be about 1/4" by 1/4" square.I need a finnish that is pleasing to the eye, if you know what I mean.
#108417 04/04/2004 12:34 AM
Len
A modern method used in body shops is to glue metal panels together with a special adhesive. This might work for you - a very strong bond and you would not risk discolouring the stainless with too much heat.
Junior Member
Junior Member
Being a welder I'd go for the welding,not much of a fan of glue,but I do know they use it very succesfully in body shops now.what is it your making?
Tig ( tungsten inert gas ) weld it. Tig is used for stainless. It can be polished after you weld it.
JS
"I can go anywhere...for I am a Piewagoneer...To the Piewagon"
1966 Chevy Panel Delivery 1966 in the Gallery and more on Webshots
JS
Making a grill for my 38 1/2 ton. I had all the bars etc made out of 24 gauge stainless. I haven't experimented with fastening the parts yet. I figure I will be able to lap weld all the pieces. My first thought was to silver solder but am open to all information I can get. It needs to be a finished product in the end that is "pleasing to the eye"
Len
Anonymous
Unregistered
Anonymous
Unregistered
len - I add another vote for TIG welding. I have a buddy that tig welded a bunch of stainless for me, once he was done I lightly ground the welds, sanded and polished. Now you cannot tell that the welds are even there. Looks like a single piece of metal.
Junior Member
Junior Member
Definately go with the tig welding,I tig weld stainless all day long and needless to say am a big fan of it.I try to make all my stuff from stainless once its done you can forget about it.it doesnt fade,chip,peel,or rust.
Looks like tig welding has won, no contest.
Thanks for the input.
Len grin
