4 members (Otto Skorzeny, J Lucas, TexasA&M48Truck, Ed Atkisson), 86 guests, and 6 robots.
Topics128,021
Posts1,055,373
Members48,420
#108359 07/13/2004 4:14 AM
Junior Member
Junior Member
sorry, what I meant was can a new floorboard be bought. I have to pull the seat out to fix a gas tank leak etc. so maybe now is a good time to fix floor board- no fun when it rains which it does once in a while in California
#108360 07/13/2004 10:39 PM
7
7 Offline
Yes...I was looking at them the other day. You will need to ask others who is the best to work with, but here is the link they have for a list of suppliers...
http://www.stovebolt.com/links/parts.htm#gm
The one I was looking at was http://www.americanclassic.com. But I need to look further before I decide. smile
Good luck!
Stella
1970 Monte Carlo 355
1987 Camaro IROC-Z 305 TPI
1955 Chevrolet Second Series
GET-R-DONE
#108361 07/13/2004 10:44 PM
I think most all of the reproduction sheetmetal comes from the same manufacturer, regardless of whichever vendor you buy it from-but I'm not totally sure. Someone with experience in this area will chime in, I'm quite sure. smile
Is your rusted out area very large? If not, you may be able to fabricate your own patch panel and weld it in. It would be quite hard to form if the rust is in areas with curves or the reinforcing ribs.
Regards,
Wannabe smile
"Don't expect anything and you'll never be disappointed"
#108362 07/14/2004 9:39 PM
I purchased patch panels for in front of the seat base last summer from Chevy Duty. I do not know if all vendors sell the panels from the same manufacture, but Chevy Duty sells TriPlus and Auto Concept parts (I may not have the names exact, I am going off of memory). Anyway, here is a picture frm July 2003 aftet I installed the panels. Its not a direct shot of the panels, but its the only picture I have that shows them.
[img]http://aricv.0catch.com/images/Cab7_19.jpg[/img]
These panels extend slightly past the front of the seat base (about 1"). They seem to fit decently, but took a little work to get them in.
BiggerHammer
"The key is in knowing where to hit it"
#108363 07/16/2004 2:13 AM
As far as I know, there are two main versions being sold right now. The older style has a front left floor board, a front right floor board and a toeboard that goes right across. A newer product has the bottom half of the right side of the toe board and floor combined ( complete with the angle) and one for the left side. These seem to be made from a thinner gauge than the older style. I am using the older style because I like the heavier gauge better.
1951 1 Ton Completed
