1 members (Bill Hanlon),
181
Mod | | | Forums66 Topics128,108 Posts1,056,239 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Who makes/converts a HEI set up for a Studabaker V8 ? Thanks in advance
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | I have grafted a GM HEI upper housing onto several non-GM lower distributors. Any halfway competent machinist should be able to do the same thing. Which direction does the Stude distributor turn? CCW rotation would need a Buick or Olds upper, CW would need a Chevy. Jerry
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | anybody else have an idea
| | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | http://www.swapmeetparts.com/servlet/StoreFront This guy knows his stuff! Nice to know if you're talking 289,or what? What year? Truck or car?? I contacted Dan,at "Swapmeet parts",and inquired about an HEI for a Studie V-8. He usually replies within 24 hours. When I receive his telephone number,I'll send you a P.M. Then you can talk to him directly. I bought my HEI,with a set of wires,for less than most want for the "Dizzy" itself,plus Free Shipping! The old 245 Stude flatheads,('48-'53), had Delco-Remy dizzy's. That's the thing with Studebaker,IHC,and American Motors...Starting in the late '50's, They used different parts,(especially electrical),depending on low bid that year. I had a '67 International pick-up,with a 304,and the distributor was Delco-Remy). it took a "Ferd' 302,(Motorcraft) distributor cap!! See what I mean?
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | okay, thanks will email at ebay site
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | The engine was a 1955 Studebaker 259engine
| | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Dan just let me know. He has nothing for Studebaker. SORRY!
| | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | I just "Googled" "Distributor for '58 Studebaker 259 engine". even though there were no HEI's listed for Studebaker,all the regular "dizzy" parts came back as AC Delco. You may be able to cross-reference your "Dizzy",to a compatible HEI unit. Check with your local F.L.A.P.S.,or follow previous suggestions,from H.R. L. Jerry knows his stuff! | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Do you specifically want an HEI or want to get rid of the points? My Pertronixs catalog shows Studebakers came with Delco, Autolite, or Prestolite distributors. If you contacted them with your distributor number I'd be surprised if they don't have a conversion for your unit. I made an HEI for my straight 8 Buick by using an Olds V8 that was turned down 0.060 where it fits into the block (length inside the block same as Buick dizzy) and replacing the Olds shaft with a longer Chevy shaft which was cut to length and had the oil pump drive tang milled on the end. We have a lap of the U.S. planned this summer in our old 1937 Special if gas stays down and the ONLY reason I chose HEI over Pertronix is we can stop at any parts store if needed.
Evan
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | yeah, my buddy wants HEI. He doesn't want pertronix(as I have)just trying to help him in his quest...
| | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 |
| | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | I did the Stovebolt Delco. Remy conversion. He's done Studebaker conversions though, I've read the posts. Very helpful with information also. Good luck. Jim | | |
