| | | Forums66 Topics128,274 Posts1,058,432 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | What front end bolt in kits are available for my 58 GMC truck. Stock right now
Thanx
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "converting" what? "front end" covers a lot of territory .... sounds like you may need to search the HiPo forum
Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | There are kits for tapered roller bearings, brakes and steering. If you want to switch from leaf to coil/bags. I'm out.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Sorry 4 being vague. What conversion kits are out there to replace the whole front end between the wheels<---for suspension brakes and all; like the mustang2 kit. Wanting the good, the bad, the ugly on kits
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I don't think there's any "bolt in" kits for that, they all pretty much are either going to need welded in, or require some sort of frame modifications to work. I will tell you, just from my experiences with them, stay away from anything Mustang 2 based. The Mustang 2 frontend is way too light to even be considered for any full size truck, like sending a boy to do a mans job, as Jerry would put it. If you do use a kit, find one that uses either GM Metric chassis (A and G body '78-'87, F body '78-'81) or C4 Corvette ('84-'96) parts. Or even better, if you don't mind a little fabrication, the entire C4 Corvette suspension crossmember can be had for less that what any of the conversion kits cost, and it's better parts. A crossmember from the '98-'12 Crown Victoria would also be a viable option. A '73-'87 C10 crossmember could also be used if you want to keep truck rated parts, but it will be a little wide.
Bill Burmeister | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 |
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | What would you like this kit to accomplish? In other words, what do you see yourself using your truck for?
Many folks get a truck, take it apart without a plan
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | everyday driving.I hasn't been on the road in 2yrs.I am either gonna start enjoying it or I am gonna get rid of it.So I bought a 3spd manual trans wOD.The truck is totally stock.so you know it looks/is high in front. Jut seeing what I can do for smooth ride without breaking the bank
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Rebuild the stock springs and add the polyvinyl leaf liners and good set of gas shocks. You would be surprised at how well they really do ride and handle.
Bill Burmeister | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | I think a nice rebuild with modern components is the way to go. My 65 c10 rides better than my 04 dodge
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Been focused too much on the car that I forgot about my Other "6"
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | what about a dropped axle set up from droppedaxles.com ?
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Nobodys used this guy
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You mean Sid's ? I've never used them personally, but have never heard a bad thing about them either. If I were to lower my truck, that's the way I would go.
Bill Burmeister | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Yes referring to droppedaxles.com Thinking this is the way to go with my truck but am looking for feedback
| | | | | Joined: Mar 2015 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2015 Posts: 26 | Longbox55 I have a 55 3100 short bed. Is the Mustang 2 too light for it? | | | | | Joined: May 2005 Posts: 85 Shop Shark | | Shop Shark Joined: May 2005 Posts: 85 | Hi,
I rebuilt the stock front suspension, brakes, added a front sway bar, pulled one leaf out of the front and installed new 3 inch lowering springs on the rear of my '56 short box. Also added radial tires and tapered roller bearings. It rides and steers better than new. | | |
