| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Looking at ideas for painting my 1 ton. I am doing this whole truck myself and am on a tight budget as I only intended to build a 1/2 ton. Weird how these trucks seem to follow us home hey? I want it to look big, mean and sleek. The1/2 ton will be the elegant one. I figure a flat black with silver and chrome detailing would look pretty sharp. I read this article: http://www.hotrod.com/how-to/paint-...-affordably-flat-painting/#__federated=1 Looks like this might work for me. But I ask this: Is there a way to top coat/ seal in this paint job? Did I miss something? | | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | Hey Fox - for most people the intent of the flat black was a cheap primer job to to give it all one color. If you intend on putting on a flat clear coat you are getting into more money. You can also buy a single stage flat paint that is automotive grade or you can get the John Deere version. No disrespect intended to anyone with either, it is just about what you want to spend vs how long you wish it to last. I wanted the same look as you but I ended up with using a flat clear over a 2004 GM sunburst orange metallic color. Looks fantastic on my test panels but it is all real paint that cost me real money Good Luck
36 Chevy 1.5 ton - rusting away 52 Chevy 3100 - in progress 72 Chevy K20 - DD
PANTS UP DON'T LOOT! PANTS UP DON'T LOOT!
NEVER watch another man eat a banana.
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Another possibility is using tractor paint. If you have a local tractor supply a lot of them have tractor and implement paint. Tractor Supply is local to me and I've used both Valspar and Majic paint on my truck. Tractor Supply Matte paint link. . I've not used this black but have used both cream and gloss black. My truck picture here. Hope this helps in your decision. Have fun and good luck. Dan | | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | Chev....is that really TS paint on your truck????
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Dan, that truck looks pretty sharp. Sweet. Thanks for the input fellas! | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Yes that is tractor paint. As a matter of fact the cab and front end is BPS(Valspar) and the bed is Majic. Colors matched quite well. Hardener was used with both. Dan | | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | Well you've sold me brother! That looks mighty fine and just what the '36 1.5 ton is looking for. Nice color too. Might hit ya with a pm later to get the color and some mixing advice. Thanks!
| | | | | Joined: Jan 2015 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 34 | Dan, was the hardener included with the paint? If not, what brand did you use? David
1952 Chevy 3100
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Yes hardener was an additional cost. Here's the one I used last. You can catch all their paint at Tractor Supply on sale. Sign up for there online flyers. Good Luck and have fun. Dan | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Look up SPI (southern polyurethanes) They sell single stage and base/clear with a flatter. Higher end UV protection without a high price. I squirt a lot of majic paint, but not on a truck I spent many a hour and split many a knuckle on. | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Yet another option: Sherwin Williams offers Barrett Jackson Restoration Paint Kits, in gallons and quarts. It's 2-part urethane, so it should paint and last better than Rustoleum. Still single stage, no clearcoat needed. Pricier than the Rusto option, but cheaper than full custom stuff. It comes in a Satin Black. Lots of videos on Youtube about it. Check it out: Barrett Jackson Paint Kit -MIchael | | |
