2 members (TexasJim50, Gdads51), 108 guests, and 0 robots.
Topics128,049
Posts1,055,740
#1081747 01/27/2015 3:31 AM
I'm restoring a 52 GMC 1/2 ton truck that appears to have had the entire drivetrain changed out sometime during it's life. It has a 235 engine, with a 4 speed transmission that has an ID of GM5 591568. It has a DANA 44 10 bolt rear end, but I can't seem to identify the axle. I found the numbers 9 5 7A3 and then 967A and 6029 stamped below that on the passenger side axel tube. I'm assuming these identify the axel but I can't seem to bring up these numbers in my searches. Can anyone help me with this? It differential appears to have a 3.73 gear ratio and it has positive traction.
47 Willys CJ2A
52 GMC 1/2 ton
Crusing in the Passing Lane
Dana 44 is a Dana axle. 10 bolt axles are a GM product, many parts interchange.
How many lugs doe the axle have? Very good chance it may not be a GM axle, perhaps from a Jeep or Isuzu.
Bill Burmeister
It has 6 lugs. Here is a link to a picture of the axle:
https://www.dropbox.com/s/h4ng7p4fp3io24i/2015-01-24%2011.55.06.jpg?dl=0
47 Willys CJ2A
52 GMC 1/2 ton
It has 6 lugs
47 Willys CJ2A
52 GMC 1/2 ton
