8 members (Peggy M, Gray_Ghost, David Bush, TooMany2count, Tronman, JW51, Wayne67vert, Shade Baby),
119
0
Mod | | | Forums66 Topics128,052 Posts1,055,716 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2000 Posts: 28 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 28 | Hi, I'm rebuilding the bed on my 51 1 ton. Unfortunately, I wasn't the one who disassembled it. My question is on the bed strips. The one tones have a flange on the bottom of the front panel. Do the bed strips go under or over this flange? Any help appreciated. Phil 51 3800 | | | | | Joined: Dec 2011 Posts: 241 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 241 | Can you post a picture of what you are referring too?
Mark | | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | If you are rebuilding a 1 ton with a regular long box then the front panel lip sits on top of the boards (if I'm wrong 'bolters please correct me). The bedside angle strip sits on top of the boards. The rear end of the boards sit up on top of the lower lip of the rear cross sill. Hope this helps!
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Sorry, I didn't read closely enough. On my one ton the bed strips go under the front bed panel. | | |
