1 members (stlcardinalsguy),
115
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 49 | Any suggestions for an alternator on a 1954 chevy truck that has been converted to 12 v.
Thanks!
Scott M.
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Just went through a similar process on my project, I decided on a GM SI series 3 wire alternator. it has better voltage sensing capabilities over the 1 wire, but many go with the 1 wire because of it's simplicity and it does work. If you're already wired for 3 wire that's how you should go. If not it's not hard to wire, but a 1 wire is as simple as it gets.
Good luck Dave | | | | | Joined: Feb 2012 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 70 | I am curious about this as well. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | One of my 1954 Chevrolet pickup trucks has had a one-wire 12v alternator in it for 16+ years. It has always worked fine.
There was no need for an indicator light wire in that truck, and the alternator self-"excites" every time (due to the normal higher idle at start-up) eliminating the need for an "excitation" wire.
| | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Only one to get Randy Rundel fifth ave. garage. With his alternator you don't need to rev the engine to get it excited . A great guy and stands by his products! Look him up on the net Fifth Ave. Garage. Steve
| | | | | Joined: Dec 2013 Posts: 795 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 795 | scooter m., This link should provide plenty of information to help you select an alternator. Good luck, | | | | | Joined: Feb 2012 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 70 | What clock position works well for a stovebolt motor? I am thinking 9. | | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | I have been using one wire alternators for years and years with out any problems. The normal starting rpm is enough to energize them, if not, a slight blip of the throttle will work, no high rpm is needed. Be sure to use 10 gauge or heavier wire off the back terminal.
Joe | | | | | Joined: Feb 2012 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 70 | Based on the MadElectrical website, I think this will work for me.
12SI, 94 amp, at 3:00 (AC-DELCO # 321-266, Lester #7294-3)
Tell the auto parts counter person that “The alternator is for a 1984 High performance Chevy Camaro, with 5.0L (305G) engine, 94amp alternator
OR
12SI, 78 amp, at 3:00 (AC-DELCO #321-247, Lester #7278-3)
Tell the auto parts counter person that “The alternator is for a 1985 Pontiac Firebird, 5.0L (305H) engine, no air conditioning, H.B.L. only.” (H.B.L. = Heated Back Light–meaning rear window defroster) | | | | | Joined: Dec 2014 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 49 | Thanks for all the suggestions.
Scott M.
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | One wire alternators are great for what they do. But there is a reason GM used the sensing wire and the exciter wire.
Depending on your wants and needs, either should work well.
The one you have picked should be fine.
