Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Sjm, Hotrod Lincoln, klhansen, 1 invisible), 129 guests, and 5 robots.
Topics128,281
Posts1,058,464
Members48,490
#1081563 01/26/2015 6:54 AM
Any suggestions for an alternator on a 1954 chevy truck that has been converted to 12 v.
Thanks!
Scott M.
scooter m. #1081575 01/26/2015 1:40 PM
V
V Offline
Just went through a similar process on my project, I decided on a GM SI series 3 wire alternator.
it has better voltage sensing capabilities over the 1 wire, but many go with the 1 wire because of it's simplicity and it does work.
If you're already wired for 3 wire that's how you should go. If not it's not hard to wire, but a 1 wire is as simple as it gets.
Good luck
Dave
scooter m. #1081680 01/26/2015 11:31 PM
I am curious about this as well.
scooter m. #1081685 01/26/2015 11:53 PM
One of my 1954 Chevrolet pickup trucks has had a one-wire 12v alternator in it for 16+ years. It has always worked fine.
There was no need for an indicator light wire in that truck, and the alternator self-"excites" every time (due to the normal higher idle at start-up) eliminating the need for an "excitation" wire.
scooter m. #1081735 01/27/2015 3:00 AM
Only one to get Randy Rundel fifth ave. garage. With his alternator you don't need to rev the engine to get it excited . A great guy and stands by his products! Look him up on the net Fifth Ave. Garage.
Steve
scooter m. #1081743 01/27/2015 3:22 AM
Former BMW Rider
Former BMW Rider
scooter m.,
This link should provide plenty of information to help you select an alternator.
Good luck,
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
scooter m. #1081772 01/27/2015 6:00 AM
What clock position works well for a stovebolt motor? I am thinking 9.
scooter m. #1081817 01/27/2015 4:33 PM
I have been using one wire alternators for years and years with out any problems. The normal starting rpm is enough to energize them, if not, a slight blip of the throttle will work, no high rpm is needed. Be sure to use 10 gauge or heavier wire off the back terminal.
Joe
scooter m. #1081834 01/27/2015 5:48 PM
Based on the MadElectrical website, I think this will work for me.
12SI, 94 amp, at 3:00 (AC-DELCO # 321-266, Lester #7294-3)
Tell the auto parts counter person that “The alternator is for a 1984 High performance Chevy Camaro, with 5.0L (305G) engine, 94amp alternator
OR
12SI, 78 amp, at 3:00 (AC-DELCO #321-247, Lester #7278-3)
Tell the auto parts counter person that “The alternator is for a 1985 Pontiac Firebird, 5.0L (305H) engine, no air conditioning, H.B.L. only.” (H.B.L. = Heated Back Light–meaning rear window defroster)
Joseph_Y #1081841 01/27/2015 6:28 PM
Thanks for all the suggestions.
Scott M.
scooter m. #1081869 01/27/2015 9:42 PM
One wire alternators are great for what they do. But there is a reason GM used the sensing wire and the exciter wire.
Depending on your wants and needs, either should work well.
The one you have picked should be fine.
