9 members (1955 1 Series, Otto Skorzeny, JW51, Greg_H, Bill Hanlon, Ponchogl, Gdads51, Peggy M, TrknGMC), 66 guests, and 1 robot.
Topics128,049
Posts1,055,689
#1080778 01/22/2015 3:10 PM
any one have a viking with front shocks? need a few photos to see how they mount...bracket on mine are farmer torched
1959 Chevy Viking 60 & Wrecker
See I told you it would work. That Beaver Cleaver will do anything.....
Here's a video,of a '56 6400 frame being loaded. the mounts should be the same,since it's a T.F. a couple of good views of passenger-side mount.
Mo' Tater
awesome!thanks so much all i have left is the hot rivets and plate.
Dan,
I am copying the info I posted on your Parts Wanted thread here as well...it might help others in the future.
PARTS NEEDED TO ADD SHOCKS
REAR
7.380 57-59 Ser 4-5-6, Shock Absorber Axle Bracket Left Rear...3763691
7.380 57-59 Ser 4-5-6, Shock Absorber Axle Bracket Right Rear...3763692
7.395 57-59 Ser 5-6, Shock Absorber Cross Member Rear...3818327
7.345 57-59 Ser 6 Shock Absorber Rear (664CC) (04N10/A1)...5534401 (2) required
FRONT
7.380 57-59 Ser. 4-6 (exc. D-D), Shock Absorber Axle Bracket Left Front (stamped 3734059)..3736689
7.380 57-59 Ser. 4-6 (exc. D-D), Shock Absorber Axle Bracket Right Front (stamped 3734060)..3736690
7.395 57-59 Ser. 4-6 (exc. D-D), Front Frame Bracket....3737927 (2) required
7.345 57-59 Ser 6, Shock Absorber Front (651T) (03J10/C2)...5521698 (2) required
7.345 57-59 Ser 6 w/ HD front axle, Shock Absorber Front (651X) (03J10/C2)...5532425 (2) required
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
thanks so much Mike...i made a copy of that I use to reference.
Thanks,Mike! Part#'s are BETTER than pic's! And these are for '57-59's. Must be different than T.F. '55-'56's? You learn something new everyday.
Mo' Tater
