| | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | My 49 has the tracks on the inside for door seals does anyone make those tracks? some of mine have been destroyed. Who makes the seals that go into those tracks ?
Also, is there a good reference of how the seals and weatherstripping are attached ? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | All the vendors sell the seals, a common consensus here is Steele Rubber Products are the best overall. The factory assembly manual contains a drawing on how they are installed. The best way is to search the topic here as there are numerous posts and suggestions on installing them.
Jim Carter sells a replacement track section, Item #CB360 is a 12" section, that is the only one I have seen offered | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Brad, thanks... I will check that out | | |
