| | | Forums66 Topics128,139 Posts1,056,758 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 38 | Looking to add this safety upgrade to my truck, what is out there? Are there original options or is everything aftermarket? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No factory option I'm aware of for trucks. Anything out there would be aftermarket. You can find original aftermarket hazard flasher setups on ebay, but they tend to be very expensive. Most of them also do not list as being compatible with trucks before 1960. I don't recall the exact sit, but I did find one that showed how to make your own, if you're not adverse to doing some fabrication.
Bill Burmeister | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Signal-Stat Flarestat 105 switches were offered by GM as a dealer added accessory. | | | | | Joined: Dec 2013 Posts: 29 New Guy | | New Guy Joined: Dec 2013 Posts: 29 | Depending on how the rest of your turn signals and lights are wired up this site I've used a reference on my own truck. The hazard lights set up is at bottom of the page. http://www.how-to-build-hotrods.com/turn-signals.html | | | | | Joined: Jan 2007 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 38 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Signal-Stat Flarestat 105 switches were offered by GM as a dealer added accessory. Those are one of the style of flashers I saw on Ebay. Even used ones are running a bit on the high side, average starting bids are $35-45. NOS are almost always $150 or more.
