7 members (TexasA&M48Truck, Nick in Manitou, UtahYork, Ponchogl, Peggy M, 2 invisible), 104 guests, and 4 robots.
Topics128,077
Posts1,056,014
Members48,433
#1079276 01/14/2015 11:37 PM
Was wondering what people would recommend for an automatic transmission swap. I have the 235 with 3 on the tree set up right now. 350? 700? Keep as is? Let me know what has worked out there. Thanks.
depends on what you're looking for, the original 3 speeds work fine for general purpose driving, it'll take some modifications for any automatic to be adapted to a 235 and to the frame - the 350 seems pointless unless you're just tired of shifting, the 700R4 w/ OD is nice for highway driving
I kept my 3 on the tree, cause not everybody has one. Plus I think it's neat. JMO.
Brian
Brian
1955.2 3100 Truck
what have you heard about the 200 transmission?
Too light duty for truck use. The only truck application was 4 cylinder 2wd S10s. Other than one odd use of it in a Caprice, it's pretty much a compact and mid size car transmission. The 700 is far better investment if you want an automatic.
Bill Burmeister
Hey guys what about a 3onthetree with OD.
Its what I am installing in my truck . grin
Danny
1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
Which one do you have? If it's the early SM319 from either a Truck or '55-'57 Passenger, it's a direct bolt in, no alterations needed other than making sure the shift arms match and adding the lockout cable and wiring. If it's a later Saginaw based overdrive, they are slightly longer and will require a shorter driveshaft.
Bill Burmeister
It is a SM319. I built it for him.
Fred
thumbs_up cool
Danny
Cool. I didn't realize that you were the source of Danny's transmission, Fred.
Bill Burmeister
This one went rogue and jumped the fence in search of a new and exotic location.
Fred
