| | | Forums66 Topics128,095 Posts1,056,069 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 38 | Was wondering what people would recommend for an automatic transmission swap. I have the 235 with 3 on the tree set up right now. 350? 700? Keep as is? Let me know what has worked out there. Thanks. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | depends on what you're looking for, the original 3 speeds work fine for general purpose driving, it'll take some modifications for any automatic to be adapted to a 235 and to the frame - the 350 seems pointless unless you're just tired of shifting, the 700R4 w/ OD is nice for highway driving
Bill | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | I kept my 3 on the tree, cause not everybody has one. Plus I think it's neat. JMO.
Brian
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jan 2007 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 38 | what have you heard about the 200 transmission? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | what have you heard about the 200 transmission? Too light duty for truck use. The only truck application was 4 cylinder 2wd S10s. Other than one odd use of it in a Caprice, it's pretty much a compact and mid size car transmission. The 700 is far better investment if you want an automatic.
Bill Burmeister | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Hey guys what about a 3onthetree with OD. Its what I am installing in my truck .
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Which one do you have? If it's the early SM319 from either a Truck or '55-'57 Passenger, it's a direct bolt in, no alterations needed other than making sure the shift arms match and adding the lockout cable and wiring. If it's a later Saginaw based overdrive, they are slightly longer and will require a shorter driveshaft.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | It is a SM319. I built it for him. Fred
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Cool. I didn't realize that you were the source of Danny's transmission, Fred.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | This one went rogue and jumped the fence in search of a new and exotic location. Fred
