5 members (1955 1 Series, Southerntruck, tclederman, Rusted Nut, Peggy M), 38 guests, and 8 robots.
Topics128,010
Posts1,055,308
Members48,419
#1080572 01/21/2015 6:19 AM
The cab lights on my 68 c50 are apparently attached to the dimmer on my head light switch. When I dim the dash lights my cab lights dim also. Is this normal or has someone hooked something up wrong?
pipeliner78 #1080573 01/21/2015 6:30 AM
Thats not normal. Someone probably just hooked them up wrong. Marker lights were not required in all states for trucks that did not run interstate. It is common for all kinds of jerry rigging to be done on older trucks.
pipeliner78 #1080577 01/21/2015 7:19 AM
Sounds like somebody wired it to the rheostat,instead of the Aux. terminal. Should be a super easy fix.
Mo' Tater
pipeliner78 #1080597 01/21/2015 2:29 PM
Is there a spot in the fuse box where they would be hooked to the rheostat or somewhere else? Thanks.
pipeliner78 #1080701 01/22/2015 2:56 AM
They get hooked to the headlight switch as do the dash lights (which are on the dimmer). The Cab light wire just needs to be moved off of the dash light terminal and on to the running light terminal to fix it...as Willy said easy!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
pipeliner78 #1080732 01/22/2015 5:20 AM
Ok thanks everyone.
