2 members (59 fleet, KEVINSKI),
157
Mod | | | Forums66 Topics128,034 Posts1,055,551 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | befor you put your saternigt war paint on,i tried the search,all I found was sales.was there power steering option for 2n series 55panel or truck? thanks. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes, there was a power steering option, it was RPO 350 (6 cylinder) and RPO 351 (V8). It was the linkage type, with a control valve built into the drag link and a hydraulic ram mounted to the axle. The pump was run off the back of the generator. The system was reproduced at one time, somewhat pricey at $600-$700, not including a pump.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The aftermarket system that Bill references may still be available from CPP or Brothers. However, I believe they are closer to $900 now. I had some experience with one and after many attempts to get it to perform correctly I sent it on it's way. It's unlikely that you will find a factory system. I have only seen a couple of them which were on high end trucks and the owners weren't giving them up. I have had success with installing the Toyota conversion on TF trucks. They are now becoming scarce and pricy as well. The box that is used is from an 84-87 4x4 pickup and there was a limited number of them produced. I have the conversion on my 56 and it works great. Fred
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | CCP might be the only ones that still carry the original style system, everyone else seems to have discontinued it.
