1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 60 | Hello, does anyone know if a 68-250 will bolt up to my 49 1/2 ton truck?
Thanks!!
Bill Muse | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The 194/230/250/292 engine series are different than the 216/235 or whatever you currently have. It can be done however, with some modification. You will need the stick shift bellhousing from the 250 (same as a V-8) which can be used with your stock transmission. The 250 truck bellhousing has different mount locations than your 49. Some have used the crossmember from a 54 which can be used with the later bellhousing. The front mounts are also different. There are aftermarket front (side of engine) tubular crossmembers available for V-8 conversions. One of these could likely be used for the conversions. Or you could manufacture a front mount. Nothing is easy, there are no direct bolt in's except the stock equipment. Fred
| | | | | Joined: Aug 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 60 | Thanks Fred. I think I will skip this engine deal. | | | | | Joined: Jun 2007 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 56 | Chassis Engineering Inc makes engine mounts for the 194/230/250 and frame mounts for the AD truck. That's what I used. It's a little work, but the results are worth it... much lighter and more powerful, and it bolts up to more types of transmissions.
1947 Chevy 3100 - Shop truck - 250 L6/T5/4.10's 1970 Chevy Camaro - Rotisserie jail
