1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#1079785 01/17/2015 5:17 PM
Hello, does anyone know if a 68-250 will bolt up to my 49 1/2 ton truck?
Thanks!!
Bill Muse
The 194/230/250/292 engine series are different than the 216/235 or whatever you currently have. It can be done however, with some modification. You will need the stick shift bellhousing from the 250 (same as a V-8) which can be used with your stock transmission. The 250 truck bellhousing has different mount locations than your 49. Some have used the crossmember from a 54 which can be used with the later bellhousing. The front mounts are also different. There are aftermarket front (side of engine) tubular crossmembers available for V-8 conversions. One of these could likely be used for the conversions. Or you could manufacture a front mount. Nothing is easy, there are no direct bolt in's except the stock equipment.
Fred
Thanks Fred. I think
I will skip this engine deal.
Chassis Engineering Inc makes engine mounts for the 194/230/250 and frame mounts for the AD truck. That's what I used. It's a little work, but the results are worth it... much lighter and more powerful, and it bolts up to more types of transmissions.
1947 Chevy 3100 - Shop truck - 250 L6/T5/4.10's
1970 Chevy Camaro - Rotisserie jail
