| | | Forums66 Topics128,184 Posts1,057,271 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 26 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 26 | Hello, its been a long time since I've posted here! Good to see my user name is still valid! Anyway, I did this swap years ago with my 1948 Chevy 3100, and am looking to do it again with a 56 3200. I want to replace the three on the tree with a factory 4 speed with creeper gear. I know it will bolt on at the engine, can't remember if I'll need a different crossmember or ujoint at the rear? Any info is appreciated! I already have the trans out if a 53 that had a torque tube.
1942 Chevy G7104 1.5 ton 4x4 1946 Willys CJ-2A | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Blue66, you will need to change the rear output cover to an open drive type and find the appropriate output yoke for the transmission, I'm not sure if the "U" joint is larger than the 1/2 ton one or not. | | | | | Joined: Jan 2000 Posts: 26 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 26 | I know on Ad trucks the u joint is different. Anyone know if the u joint for a half ton 3 speed is different than the half ton 4 speed?
1942 Chevy G7104 1.5 ton 4x4 1946 Willys CJ-2A | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the U-joint is the same, but driveshaft length will be different
Bill | | |
