0 members (), 129 guests, and 3 robots.
Topics128,110
Posts1,056,241
Members48,437
#1078789 01/12/2015 4:15 AM
Trying to help a friend put together a basket of parts with many of them missing. Looking for front and rear spring seats and spring wedges. I've tried:
brotherstrucks.com
lmctrucks.com
oldchevytrucks.com
fillingstation.com
chevsofthe40s.com
with no luck. Any suggestions?
Are you asking about the "U" bolt to axle, or the spring to frame? The U bolt goes over the spring and into the flange cast into the axle in the front. No seat, just a wedge for caster and a plate for the shock mount. In the rear, the axle is on top of the spring and clamped with the U bolts to the shock mount under the spring. The back side mount is just a U channel with 2 holes that the u bolt goes through. Get a shock mount "lower" and make the other piece if you can not find it in the pile of bits. Here is the picture from the manual for 52 to 54:
http://chevy.oldcarmanualproject.com/shop/1954truck/54ctsm0456.html
If you have the "lever" type shocks then it is different.
Steve H
Caster shims/wedge can be had. Here is one place. I am certain there are others:
http://www.wfoconcepts.com/cr/2-Inch-Axle-Shims/3225/4382
Good luck and let us know how it goes
Steve H
Most local spring shops carry the castor shims in several degrees.
