| | | Forums66 Topics128,089 Posts1,056,130 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 26 | Trying to help a friend put together a basket of parts with many of them missing. Looking for front and rear spring seats and spring wedges. I've tried:
brotherstrucks.com lmctrucks.com oldchevytrucks.com fillingstation.com chevsofthe40s.com
with no luck. Any suggestions? | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Are you asking about the "U" bolt to axle, or the spring to frame? The U bolt goes over the spring and into the flange cast into the axle in the front. No seat, just a wedge for caster and a plate for the shock mount. In the rear, the axle is on top of the spring and clamped with the U bolts to the shock mount under the spring. The back side mount is just a U channel with 2 holes that the u bolt goes through. Get a shock mount "lower" and make the other piece if you can not find it in the pile of bits. Here is the picture from the manual for 52 to 54: http://chevy.oldcarmanualproject.com/shop/1954truck/54ctsm0456.htmlIf you have the "lever" type shocks then it is different.
Steve H
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | Most local spring shops carry the castor shims in several degrees.
