4 members (Hotrod Lincoln, Guitplayer, LAROKE, 1 invisible), 54 guests, and 3 robots.
Topics128,154
Posts1,056,840
Members48,456
I had to send my combo fuel/water temp gauge to be rebuilt. I thought the water temp sender thread would be a typical pipe thread. I was wrong. I need to put a temporary plug in the head while the gauge and sender is being fixed so I can use the truck. 1/4" NPT too small and 3/8" NPT too big. I thought this info would be readily available but haven't been able to find. Hoping someone can assist.
Try a 5/8-18 UNF
But not sure what a fuel/ water gauge would be.
Pretty sure that's a straight pipe thread in the head.
dg
Denny G
Sandwich, IL
Pipe thread did not start until the electric sender came in 1956.
My Blog
yes 5/8" NF. A pipe fitting looks like it will fit, and will actually screw in, but it is wrong, wrong, wrong.
Thanks for responses. Appreciated.
Searched and found this info, thank stovebolters!
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
