1 members (Shade Baby),
21
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | Hello everyone and Happy New Year. I've got a small problem. When I bought my 1949 Chevy truck it had already been changed over to 12 volts. I've just now found the time to try and fix this problem. When I put the brakes on my panel lights com on. Also when I blow the horn my parking lights come on for just while the horn is blowing. Anybody got any idea, other than a "match?" As always, thanks, Steven | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | You have a grounding issue. For testing, you need a ground wire from the cab to the frame. From the engine to the frame. and it helps to have a ground wire from the front fenders to the frame. One more for the bed to the frame and then see what happens. If the issue goes away, then make some good looking straps and tuck it all nice and neat.
Steve H
| | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | Thanks, I will try that and see what happens. Have a good day. Steven | | |
