3 members (Cosmo, JW51, 1 invisible),
131
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | neither factory nor dealer
Bill | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Agree with red58. A 'custom' look somebody liked. Beautiful workshop by the way.
Drew
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I need to do that to mine to cover up where the paint is peeling just under the curled over part of the bed side. I guess the painter had a hard time wiping that spot down before final color. I'm thinking about old weathered tongue and groove siding. Carl
| | | | | Joined: Jul 2013 Posts: 159 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 159 | Thanks. I built it just to restore my '51....the wife thinks it should be included in the project budget....unless I build her a t-bird next... | | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Interesting look. It must be a New England thing....perhaps a take on the West Coast Woodie? My 48, which was last registered in Connecticut, had wood on the bedsides and actually had wooden running boards. It's 1/4 in plywood Carl on the sides, not T&G, however if I go back with it, thinking of switching over to Hardi board all round.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Sep 2008 Posts: 130 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 130 | I did my bed in 5/4 step treads (pine) for the sides,used my stakes,front,backmetal,and and tailgate on the wood. Even kept the slant edge on top in wood. The the bed floor is designed to lift out. I only built it to be temporary, but everybody likes it so much I desired to keep it now. I also uesed the splash pan's, running boards and fenders. I looks like a woody and added a little more weight. | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Yes, I like the shop too. Nice looking design. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | Looks similar to the Dodge Red Express trucks of late 70's. They had wood on each bed side and on the tailgate.
Mar-Ktech | | |
