0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Hi Y'all I got a "new" Chevy 52 3600 I know that the engine is newer than the truck. The ID which I found on the engine a straight 6 goes like this. 389 4257 GM 66? On the left of this is shown. 00N2 O1T2 Also trying to Identify a Carburtor. Pictures of both located here (I hope) http://s1376.photobucket.com/user/jlcjr/library/?sort=3&page=1
Julian Carter
1970 Triumph GT6 1967 Triumph TR4A 1952 Chevy 3600 1948 MG-TC
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Savannah54, welcome, you're correct, the engine is from 1963 or newer, could be a 194, 230, or 250. Are there any numbers stamped into the machined pad behind the distributor? The carburetor is a Rochestor model "B" which looks like it is an older version than the engine would have had on it from the factory, hope that helps | | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Thanks SS Thanks for replying No numbers stamped around the distributor. I'm just trying to figure this when lookin' for parts
Julian Carter
| | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Julian,his handle is "3B". "Shop Shark" is the title given to members with more than 500? posts. 3B is correct on both your engine,and carburetor. i had the same stamping on a '62 Chevy C-40 bus. It didn't have any numbers by the dist.,either. Found out that it's a 250. Welcome to the '"Bolt"! | | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Thanks 3B and wetwilly I'll see where I can go with your info.
Julian Carter
| | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | According to Leo Santucci's Inline Six power manual, your block is a '68-'88. The location of the dipstick tells this much. With out a number stamp to identify it, next option is to check the stroke. Pull one spark plug out and stick a long narrow stick down the hole and rotate the engine slowly till the piston hits bottom. A 230 ci has 3.250" stroke, the 250 has a 3.530" stroke, a good 1/4" longer. The 194 went out of production in 1967 so I would rule that out.
joe | | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Thanks Joe, I have Santucci's manual I had not read farther than the first chapter. Where did you find the reference to the dipstick location.
Also having a GM engine in a chev. truck dosen't look so odd after reading this manual. So was General Moters the parent company to Chevy and GM
Julian Carter
| | | | | Joined: Dec 2014 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2014 Posts: 72 | Easy way to tell a 230 from a 250 is that a 230 has flat top pistons and a 250 has dished. | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | General Motors is the parent company to GMC Trucks, Cadillac, Chevrolet, Buick, Pontiac, Oldsmobile, Saturn, & Hummer. In the early years most divisions had their own engines but shared engines for trucks. Most later vehicles had Corporate (Chevrolet) engines. Fred
| | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Thanks everybody, So far I've found the numbers were incorrect as posted in the first posting.
389 4257 GM 66?
00N2 C112
So I updated the Month and date to C112 this means that I have a engine made in March on the 11 of 1962. I believe the Pistons are flat top.
Thanks everybody for helping me find my way!!
Julian Carter
| | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | I was looking on page 21 of Leo's book, top photo. I think I have the second printing of the book.
Joe | | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | I found the ID next to the distributor F0417CBT
Julian Carter
| | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | From what I can find, it looks like its a 1970 or newer, the engine codes switched to three letters at that time. The C112 could be 1972. Look on the head for a casting date, it might be under the valve cover, that might help.
F -- Flint plant 04-- April 17-- Day CBT-- engine code
| | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Ok Numbers on the head onder the valve cover. From left to right.
12 GM 26 D82 084X 2962084X
Numbers on head on left side
45 F 2086 2084
Julian Carter
| | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | D - Apr, 8 - day of month, 2 - '72, matches the block code of 04-17.
Joe
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | You just have to love casting codes. I have yet to make much sense from them. But on a lighter note, What week in '72 had 8 days?
Steve H
| | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Great, I'd like to thank everyone for your help in identifying my engine.
Julian Carter
| | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | That was a special week, only one ever!
Joe | | | | | Joined: Jan 2014 Posts: 3,689 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,689 | You just have to love casting codes. I have yet to make much sense from them. But on a lighter note, What week in '72 had 8 days? Leap year!
1951 3100
