1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | Some where in this forum I read that the truck beds for a 66 step-side short bed date back further then 64 and it goes back to the late 50's. Does anyone know the year that they are the same. A guy has the bed from a 56 for sell and I need a tailgate. Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 56-66 the beds are the same, tailgates stayed the same even longer
Bill | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Check the bed forum. I asked the same question recently and mar k turned me on to their website with much reference material. Double check. The hole line up on angle braces and supports differ some. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The beds were basically the same from '55 2nd-'87, with '54 and '55 1rst being very similar. Tailgates and front bed panels are the same '54-'87.
Bill Burmeister | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | mar-K Look under installation info. GMC Pauls look under : 47-72 bed wood info. If you have more specific questions, ask the folks in the Making a Stovebolt bed forum. The people that have really taken their trucks apart, pass by there from time to time. Also, Mar-K has a tech that answers questions in there. Good luck, -W | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The fenders changed in '67 and again in '73. | | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | Thanks for the help I will check out the bed forum
