1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1077492 01/05/2015 6:52 PM
I have my eyes on a new HEI for a 235 from langdons. Anybody out there have experience with one? Opinions? Good things to know about it if I get one? I am not concerned about keeping the original look. Thanks in "advance", pardon the pun.
Lemmm117 #1077505 01/05/2015 7:52 PM
It's a good option. Quick start ups. If you have any problems Tom is more than willing to guide you. I will say, however, if you are satisfied with your existing contact point system, no real need to spend the money on a HEI.
Drew
Lemmm117 #1077537 01/05/2015 10:09 PM
The points dist in this engine I'm working on needs all new components, as it has been sitting for about 35 years outside. So rather than putting money into it, I'd rather go with a new HEI. I'm not dead set on it yet, nor one from Langdons, but they do seem to be a good way to go. However, I am willing to keep my options open for now. Thanks.
Lemmm117 #1077539 01/05/2015 10:16 PM
What parts are needed, "all new components"?
What is the price of the HEI?
How many miles per year will you be driving, and, at what speed will you be driving?
Lemmm117 #1077555 01/05/2015 11:14 PM
It's going to need new cap, rotor, points, condenser, plug wires. Probably not going to drive it constantly. Just the occasional summer cruise. I like the reliability and low maintenance of an electronic ignition.
Lemmm117 #1077557 01/05/2015 11:15 PM
What year truck are you working on?
Lemmm117 #1077601 01/06/2015 1:56 AM
It's a '53 half ton chev with a 235 out of a '56 car.
Lemmm117 #1077611 01/06/2015 2:30 AM
I only drive about 1,000 miles a years. I think I have points in my Suburban, but I have not checked in over 4 years.
Lemmm117 #1077614 01/06/2015 2:37 AM
I don't care who ya are, that's kinda funny right there.
Lemmm117 #1078282 01/10/2015 12:44 AM
Gas Pumper
Gas Pumper
You could always be a pioneer in this issue and resolve it once and for all using your stock distributor. Two completely different sources have done this with great results. Since two isn't enough, I am trying to sort it out. Here:
http://forums.devestechnet.com/foru...ojects/49-hei-for-your-stock-distributor
Whats holding me up is, I don't have a test engine available right now. In all honesty though, if you are trying to resurrect an engine that's been dormant for a long time, get the stock system working first so you have a starting point. You may not need HEI at all. Afterall, its a low RPM engine with a proven track record.
http://devestechnet.com/Home/StockIgnition
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Lemmm117 #1082583 01/30/2015 10:52 PM
Lemmm117 #1106880 06/07/2015 5:06 AM
Lemmm 117,I Sent you a P.M.
Mo' Tater
Lemmm117 #1106907 06/07/2015 1:19 PM
Mines running on modified stock distributor with TBI. Check out Bills sight at Binderplanet if you wanted to mod your old distributor.
http://www.binderplanet.com/forums/...-conversion-carb-efi.113180/#post-799563
Lemmm117 #1107187 06/08/2015 8:51 PM
purchased my HEI from Langdon's , excellent instructions,easy install
works great and takes steps out of tune ups
good luck !!!
just-a-hacker
'49 3100 before '99
