| | | Forums66 Topics128,012 Posts1,055,321 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 125 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 125 | Can anyone tell me what the sequence of washers and spring are on the pivot stem of a vent window on a 1953 pickup. I took mine apart and the sequence does not seem to be right. A photo would help.
Thanks Stan | | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Flat, fiber, vent,fiber, flat, spring,flat and nut.Sorry the pictures I had were on the phone that died. Mike
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Feb 2014 Posts: 125 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 125 | Thanks Mike. It seems Im short of washers. I only have three. One fibre and two flat with a centre flat on them.
Stan | | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | the bottom flat washer next to the nut is a regular washer with a round hole. the two fiber washers act as brakes to hold the window open at speed. you adjust that by tightening the nut
| | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | I found a picture and PM me for any other help you need.
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I used the tech tip on mine when I did it several years ago. It was excellent, pics included. | | |
