1 members (delky),
258
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 55 | Who builds a decent reasonably priced glass beading cabinet that doesn't blow sand every place? Ive had it with my harbor freight pos . | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Don't know about "reasonably priced" but I purchased a Skat Blast cabinet from TP Tool back in 2001, with the vacuums system, and have never looked back. Its 48 wide 28 deep and 28 high inside. Best 1100 bucks I ever spent. I just changed the sand/nozzle and glass saver yesterday. Sometime I wish I'd have went just a bit wider but this one has stood up to my abuse doggone good for years. I use it just about every time I'm in the shop. I think today they still sell the same unit for about 1200. From memory its called the Patriot 960 version. I like the two lights inside, easy change of media. If it don't fit in my blasting cabinet it goes somewhere else!
Note to current owners....over the last 14 years I've found the two little bearing in the vacuum motor WILL go bad. A local place charged me 18 bucks for one and I said WHOA. I found the same bearing for a buck a piece. I ordered 20 new ones last year so I have plenty. If your paying to much for them let me know and I'll give you a couple!!
| | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | I have a HF blast cabinet and like every other one they produced mine leaked quiet a bit. I did some Google research and found many ways of upgrading these HF cabinets. In the end I completely dismantled mine then, reassembled it with silicon in between the cabinet pieces. I also upgraded the gun and pick-up tube. Installed LED strip lighting, a small shop vac with a Dust Deputy, added an air dryer, and regulator. It probably took 6 hours and cost me $300. It works great for me now. My $.02 | | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | I've got the same cabinet Alvin has. Love it, and so much nicer than without a cabinet, but in hindsight, if you're doing more than one truck, sure would be nice to be able to put a fender in it. Then about all you would have to sub out, would be the frame, cab and hood. Just depends on what you're planning to do. Curt has a good idea also, since you already have one.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Alvin,
I have the next size up (970 DLX - longer than the 960): 58" WIDE, 28"D, 28"H Work Area. However, I think the length of your unit would have been OK for everything I have blasted.
It was on sale in 2008 for $1300 (they have a sale every year).
One the highest quality and most useful buys I have made. I put put a 3/4" flywood base on it (for storage) and rollers/wheels.
| | | | | Joined: Dec 2014 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 55 | I have a HF blast cabinet and like every other one they produced mine leaked quiet a bit. I did some Google research and found many ways of upgrading these HF cabinets. In the end I completely dismantled mine then, reassembled it with silicon in between the cabinet pieces. I also upgraded the gun and pick-up tube. Installed LED strip lighting, a small shop vac with a Dust Deputy, added an air dryer, and regulator. It probably took 6 hours and cost me $300. It works great for me now. My $.02 That's the same model that I have now,I might break down and try some of those tricks on my pos 1st. If that doesn't do I might have to bite the bullet and get the $1200.00 job. Thanks guys. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Tim, I know we can buy/put an extension on the cabinets we have. However, 99% of what I need, like you, I can do it in the one I have.....and room in my shop is getting to be a premium!!
....a fellow bolter, "Dakota" had made him one out of an old AD cab. Man, he could blast about anything in that thing! | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I have Alvin's and Tim's setup or something very close. Best money I have ever spent, although, put a 16" rim in there and spend a few hours blasting it, or something just long enough to fit diagonally, and you will wish for more. More is always equal to more space. Not more volume, or anything else. If you don't have TIPS vac, a shop vac will work for awhile, putting a Carbide tip on the gun is a no-brainer, but size/capacity is a big concern. I have a standing offer with friends in the local area to PLEASE purchase my 980 so I can get a larger one. There is a Demarcation. Its the boundary between doing it in the comfort of your shop, and going outside and doing it the hard way. Do you Demarc at tire rims and larger? Or after tire rims? What about the radiator bracket? Going outside to do that? You can sandblast in a cardboard box for a time. When it comes to doing it for more than just one restoration, sorting this issue out will become important enough to you, to fix it. These days, if you are a good welder, just purchase TP Tools instructions on how to make it yourself. Some 22 gauge tin and some ingenuity, you can do it cheaper. Is it worth the time to reinvent the wheel? Maybe. In my case no. My 980 model is great, lights, vac, carbide tip, NOT ideal due to space. Everything else, including my motorized small parts tumbler is just fine. I use #1 Silly Sand in mine. My mistake was not spending the few hundred more for the larger cabinet. If I could take back that decision, I sure would in a jet second. We are all different and have different needs. No right answer. I personally have a real distaste for hauling stuff outside, getting out the pressure blaster, stringing the hoses out, the tarps and backstops, waiting for Spring, etc. But that's assuming you have the CFM and your air compressors are about two times more expensive than my blast cabinet to do that. Its why everything I write about sandblasting starts off with me complaining about it.  | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | ps. mine looks more like todays 850-T. | | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Deve & Alvin -- Concur with all above. I, too, have the TP Skatblast. Been using mine for nearly 15 years and love it. Hambone uses it about as much as I do ... he can speak for himself about it, but I think he likes it, too. At anyrate, I started out going cheap with the HF blaster and quickly decided to move up to a big boy tool.
Like all said above, if you are working on a restoration, or are planning on doing a fair amount of refinishing, a quality blast cabinet is a must. Go big early. Go bigger. Get as big a cabinet as you can afford, and then, go a bit bigger. You'll thank us down the road.
I sold my pressure pot sand blaster at the consignment auction a few years back. It was a HF one anyway. And haven't looked back. If it doesn't fit in the cabinet but needs to be blasted, I happily break out the dollar gun and fire away. Suiting up and running the sand blaster ... sux. I think my personal record for continuous blasting is about 4 minutes (enough sand, enough air pressure & volume, no clogs, clear visor on my hood and no equipment breakage)
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Milliman's cabinet is great, from a guy that never used one before. The only complaint is when John leaves his sweat in the gloves. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Hambone, a pair of rubber gloves BEFORE blasting should keep away the bo-wevils  John, I hear you about selling the pressure pot. I used my new one long enough to finish my chassis and sold it for $100. It came from Tractor Supply. (same O same O) I learn my lesson quick...in 103 hot August heat. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I never thought of that. Gloves in the gloves. Great stuff. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Come on now. It just means that John cares!! | | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Hambone ... NOW he tells us (I was just thinking that he (Alvin) does look pretty squared away in his shop coat ) ...
I'll get a box of gloves to set out there ricky tick.
