1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 56 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 56 | I am putting a L6 250 engine in a 1956 Bel Air that originally had a 265 V8 in it. What motor mounts do I need for the L6 250? Can they be bolted on the frame or do they need to be welded? Suggestion on sources for these L6 side mounts.
Many Thanks, Glenn | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Last time I checked a Bel Air was not listed in the trucks catalog. Your question probably goes in the Greasy Spoon where someone with the appropriate car knowledge will answer your question. Good luck with your project.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Check with Chassis Engineering | | |
